TIA
TIA
[image: View Post]Rivcyko, on Aug 1 2009, 01:54 PM, said:
Take the pinch bolt all the way out. Should slide off the splines like butter.[image: View Post]coderighter, on Aug 1 2009, 02:16 PM, said:
Take the pinch bolt all the way out. Should slide off the splines like butter.Quote
So yesterday I got my shinny new foot pegs from Randy at Visit My Website -Knight Design LLC and they look awesome, great to have a little extra leg room in there too. Hpwever when installing I cannot figure out how to get the brake lever adjusted downward ??? Anyone have an explanation or pic of what needs to be done ?[image: View Post]coderighter, on Aug 1 2009, 11:16 AM, said:
Take the pinch bolt all the way out. Should slide off the splines like butter.[image: View Post]coderighter, on Aug 1 2009, 11:59 AM, said:
Glad you like the pegs ! If you get a chance post some pics of them.[image: View Post]Tightwad, on Aug 1 2009, 02:25 PM, said:
Here is where the adjustment points are....you can see how close I took the bolt to the brake pedal. If I needed more adjustment I would have to shave the end of the bolt:[image: View Post]Tightwad, on Aug 1 2009, 05:25 PM, said:
Here is where the adjustment points are....you can see how close I took the bolt to the brake pedal. If I needed more adjustment I would have to shave the end of the bolt:[image: View Post]VFRCanuck, on Aug 1 2009, 05:44 PM, said:
Here is where the adjustment points are....you can see how close I took the bolt to the brake pedal. If I needed more adjustment I would have to shave the end of the bolt:[image: View Post]redneck7769, on Aug 1 2009, 04:03 PM, said:
Here is where the adjustment points are....you can see how close I took the bolt to the brake pedal. If I needed more adjustment I would have to shave the end of the bolt:[image: View Post]redneck7769, on Aug 1 2009, 07:03 PM, said:
When you cut the bolt down leave the nut on the bolt. Once you have it cleaned up and the way you want it just turn the nut off the bolt to clean up the end of the threads. I do this all the time. It saves me having to buy alot of taps.[image: View Post]Ryanme17, on Aug 1 2009, 06:06 PM, said:
When you cut the bolt down leave the nut on the bolt. Once you have it cleaned up and the way you want it just turn the nut off the bolt to clean up the end of the threads. I do this all the time. It saves me having to buy alot of taps.[image: View Post]VFRCanuck, on Aug 1 2009, 08:00 PM, said:
