[image: View Post]Veefer Madness, on Aug 4 2009, 11:45 AM, said:
[image: View Post]klinquist, on Aug 4 2009, 01:06 PM, said:
Video! Autolumunation Eagle Eye Tower (red) on the top, standard clear incandescent bulb on the bottom:
http://www.youtube.c...h?v=_dqghiC3IfE
The above is a perfect example of another difference of led/incandescent bulbs........
The lower clearly shows the internal reflector, which is DOT spec'd to work with incandescent clear bulbs.
Among the other stated reasons already mentioned, a
RED led is best to not wash out the red lens with the pinpoint intensity of a white led. it almost burns through the lens looking at it.
IMHO, it's best to get leds with the most number of and multidirectional firing of those to utilize as much of the reflector as possible. A relay will deal with the heat/flash rate issues, but I've also used the resistors gooped on the inner side of my rear fender with no long term problems.
I am however interested in these,
http://www.v-leds.co...634406-1-2.html because the wattage output is greater, but still, if you consider the total of running all leds, you won't come close to the consumption rate of the originals.
Greg :fing02:
Yep, in that video I am using RED LEDs on top. It'd be nice if there was a LED assembly that had LEDs that faced "down" a bit... take the side-facing ones and tilt the bottom few down 45 degrees... that'd work much better with the reflector.
