So while I was servicing the K&N filter on the bike the other weekend I decided to block off the PAIR valve as well as unhook the flapper valve on the airbox. For the PAIR valve I took off the hose on the LH side of the airbox (on the back, the one that leads to something that looks like a valve, I think) , plugged it, then re-attached it to the airbox. For the flapper valve I simply on-hooked the vacuum line from the solenoid on top of the airbox and plugged it with a golf tee.
I only got around to riding it yesterday and noticed the idle was horrible (low, wandering, put-putty) and the bike was hard to start. There also seems to be a good bit of vibration coming up through the tank while riding. Aside from that, the bike runs great. The low-end surging/bucking has all but disappeared.
I re-attached the vacuum hose for the flapper valve but left the PAIR hose blocked. The idle improved but isn't back to normal. The vibrations are still there as well.
Did I do something wrong, or does the PAIR block-off 'mod' require me to do something else, like possibly raising the idle?
If it DOES require raising the idle, I have another question. I BELIEVE I know where the idle knob is (black knob about the diameter of a dime on the RH side near the engine case). I have tried to mess with this before, but it seems like the thing just doesn not want to turn. I'm hesitant to crank on it because I've broken quite a few things in my lifetime by being rough with them. Is there some technique that I am missing?
Mike
PS - total powertrain 'mods' are K&N, snorkel removal, and 2 Bros exhaust (slip-on).
Mike
