2002 VFR800 non-ABS just shy of 40,000 mi.
I dumped the bike back in Dec '05 and in that accident the tach quit working. Lacking funds, I didn't get it fixed.
Well, now I've acquired another instrument cluster. Turns out its from an ABS model and has 31,000 mi on it. I was hoping I could swap the tach from the new cluster to my old one. Thus leaving my mileage correct.
In case you're wondering, the tach is soldered onto the board. Its not hard to remove at all, just a bit tedious.
After removing the new tach and installing it on the old board, it doesn't work.
So, just in case the board was damaged, I tried putting the tach back on the new board. That doesn't work either.
Yes, the tach did work on the new, un-touched, board. So the wiring on the bike can be ruled out.
At this point, I have good connection between the pins from the tach, there's 4 of them, and the board but no motion from the tach.
Does anybody know how the tach works so I can begin figuring out what is wrong with my setup?
TIA
TIA
