Havent been on in awhile, but an issue has gradually been getting a bit worse, and now that Ive figured out that it's not actually my imagination, i wanted to check in....
'02 non abs, 54k miles. Gradually over the last year and especially the past few months, I thought I had been intermittently noticing the throttle response dropping off a bit, and generally just having a bit of a lack of power. The engine is still running smooth....it isnt a misfire or rough running kind of thing. But, i compare it more to as if you were riding into a strong wind constantly, or riding up a steep long grade. I have noticed at times too that the characteristic 4500rpm flat spot seems worse or more noticable than it ever has, on certain days.
The way it runs before it warms up seems a bit off too. The bike has never run all that great upon first cold startup, but last night I noticed the obvious constant hesitation all the way up until it was at normal operating temp. And even then, it seemed like it was a bit down on power. In general, warm and especially cold, it just seems to require more throttle when riding. It is noticable.
Some other info. New OEM plugs as of this year, as well as new OEM air filter put in about 3k miles ago. Starter valves were adjusted last season. No "FI" light that I have seen, although i have not checked for codes yet. Valves have NOT been checked or adjusted yet at all....but I dont feel that would necessarily cause this type of issue. As well, fuel filter was replaced about 10k miles ago, when I replaced the fuel tank due to an accident. Battery replaced last season, and charging system is at 14.0 volts while riding. As well, everything is all stock....no power commander, bike is still running stock exhaust, etc. 87 octane fuel is what I typically use.
So...any thoughts or general ideas would be appreciated, as I think the issue is slowly getting worse.
TIA
TIA
