Speedo Compensation
14 posts Started 3 Sep 2009 Last recovered post 12 Sep 2009 Wayback Machine snapshot 12 Apr 2010
Quick Question
Is there any speedo/odometer error on the VFR's I know my Honda VTX 1300 is around 10%, it is not a digital speedo\odometer.
By the way loving my bike, 320 miles 2 days. loads of rain, never felt happier.
Paul
My 07 is running at about 5-6% too fast, not as bad as my VTx was, but still wrong. Fortunately for me I try not to get too worried abotu what the speedo says, I just ride how I want most of the time as out here I go miles and miles between meeting other vehicles most of thetime.
George
Speedo is 6%-12% fast, odometer is just about spot on. :rolleyes:
If it is important to you, you can get a speedo healer and make the speedo correct and the odometer read low, or have set it in the middle of the two and be pretty close on both.
per GPS.....my 03 speedo shows a PLUS 7 mph reading with stock gearing, so 67 mph on an actual 60 mph speed bone stock.....with changed gearing (-1 in front plus 2 on rear) it now shows a PLUS 10 mph reading with this gearing change , so 70 mph on an actual 60 mph speed.
Hope this helps, actually I was glad with the 3 extra error over 7 stock as 10 mph is easy to calculate while speeding, I mean riding, thanks Doug
I was off about 8%. I picked up a speedo healer at the same time as my gear indicator. Both are REALLY easy to install.
My speedo is about 10 - 15% too high with the smaller front sprocket.
Doing the math in my head as I ride helps keep me sharp. Well, Maybe. ;p
I just wanna ride. :wheel:
The reason i asked was just to get an accurate mpg. But if the Odometer will not be affected then no worry.
When I exit the 110 fwy in chinatown everyday there is a radar facing the vehicles exiting the freeway onto the surface street. The speed showing up on the radar reads about 5mph higher than the speedo on my bike. If the posted radar reading says 35, my bikes speedo says 30.
anymore????
Mine is off from 5 mph at lower speeds to 7+ mph at higher speeds. I use my GPS as a speedometer; it's extremely accurate, and easy to see.
Mine reads about 3 mph higher than actual at 70 mph. Odo seems to be accurate though.
Mine's just under 10% fast. I set my speedo healer to pull the speedo down 9.1%.... it's within .5mph of my GPS at 80mph now.
I've always figured my speedo was showing faster than I was going. It always seemed that to drive about the same sped relative to everyone else as I do in my car or truck the bike had to be going about 7-8mph faster according to my speedo. I got a warning for speeding last weekend traveling through downtown Atlanta. I was riding to be passing most of the cars on the road like you should in heavy interstate traffic. My speedo said I was doing about 90 mph most of the time. A GA HWP trooper sitting on an on ramp got me. He told me he got me at 82 mph.
I can't believe I got a warning for 82 in a 55 on a Holiday weekend. I thought for sure I was getting the big ticket to the tune of $400+ since GA recently passed an excessive speeding fine that the state tacks onto local fines for anything 20+ mph over. The new extra state fines of course have nothing to do with safety and is a means for the state to make up its budgetary shortfall during this recession.
The odometer is off. I've run the trip meter on my GPS against the bikes trip meter several times. How far its off depends on how fast you were riding. My speedo is a pretty consistent 10% off. When I've checked the odometer against the GPS at fifty miles sometimes the bike reads 51.4ish and sometimes it reads 55 point something.
Actually I'm not sure why that is. All I know is what I've seen.
End of thread · 14 posts recovered Wayback Machine snapshot 12 Apr 2010
