Hi,
I recentely (1 and a half months ago) bought a vfr400 and due to not beeing able to ride it yet it has been sat in the garage over winter.
It started fine, no problem when i bought it.
Ive tried to start it up again and just cant get it to start
Here is what I've done:
1.Starter motor sounded weak, no high beam - assumed battery was dead/dying so hooked it up to another and charged it up whilst trying to start as the other vehicle was ticking over. Still nothing
2.Thought it was flooded and maybe damaged the spark plugs so removed the two easiest to reach spark plugs and they were slightly dirty but nothing major and after replacing them there was no difference to trying to start the bike.
3.Checked the fuel tank and put a little more fuel in to make sure it had enough, removed it to make sure fuel was running through the fuel lines. (it was)
4.Checked the Air filter when we took off the tank, it wasn't clogged/blocked.
Cannot for the life of me find out why it won't start and dont really have the funds at the moment to take it in to a garage.
Like I said, it was running fine before being left in the garage for about 1.5 months over winter (which was a bloody cold one) but now it just wont start.
When cranking the starter motor I can hear it trying to kick in, which pops ever so often and sometimes almost ticking over at about the speed the starter motor is cranking. Also ive tried different levels of choke etc & fuel tap is open.
Has anyone had the same problem/ know what the problem could be?
All help greatly appreciated, Thanks in advance!
