I changed out my sprockets to a -1/+2 and took it for a spin yesterday and noticed a speed related "wubbing" noise. it sounded like it was coming from the rear but it's hard to say for sure. I did some trouble shooting while riding. I eliminated the possibility of it being the brakes rubbing. I had the front bearings replaced after I had the rims chromed, as well as had the wheels mounted and balanced professionally. It might be just normal operation with the front sprocket not having that rubber dampener on it. The chain seems loose but when I check it with digital calipers while it's on the center stand it reads 1-1/8" slack (before and after the test ride). i put it gear while on the center stand and the chain flopped up and down more than i thought it should, but I'm not all that proficient when it comes to motorcycles. Has anyone else had this noise?
BTW I'm using a SuperSprox 45t rear and a Drivesystem USA 15t front
http://www.vfrdiscussion.com/forum/uploads/1268763429/gallery_17441_5246_95016.jpg
