Hey All,
Doesn't everything go at once? It seems like its that time of the year... I'm a noob at motorcycle maintenance... especially with these linked brakes that seem quite complex...
I have been experiancing brake drag since I installed my Galfer rear pads a few weeks ago... they were considerably thicker than the pads that were left on the bike... The pistons on the calipers pushed back in tough but I thought not much of it since I always used a C-clamp on car calipers... I put the brakes together and they were a little tight, but I figured after a ride or so they would loosen up after being broken in... wrong.
I pulled everything apart tonight... In the rear caliper, the 2 outer pistons move freely with the rear brake pedal as they should. I gather that the center larger piston should be activated by the front master cylinder on the caliper on the chain side... And it is... but boy I have to pump it 50 times to get the piston 1/2 way out... And then it takes all of my might (with a few rags over my thumb) to push the cylinder back in...
I gather this is not normal. Correct?
So I'm thinking that the rear caliper needs a rebuild...
According to what the manual seems to say... If I pull the rear caliper and rebuild it... I can put it back on the bike and just bleed the rear line... Correct?
Any guidance/advice would be appreciated before I dive into this one...
~mikeym
~mikeym
