Well, they say there are only two kinds of riders, those that have crashed and those that are going to. I am now the former. I've been riding for two years and have been lucky to have made it so long without a crash I think. At least I have a somewhat cooler story to tell about my first crash. My first crash was on the Tail of the Dragon and not the first time I rode it and not in my neighborhood coming home from work when I locked up the front tire dodging my neighbors dog and not falling over at a stop sign on a hill. :biggrin:
I was riding with my friend Matt, a USAF captain, who was on his Bandit 600. It was his first time riding in the area so I was leading. We had rode up TN-68 from McCaysville, GA to Tellico Plains and then rode the Cherohala Skyway over to Deals Gap.
We were running a pretty good pace through most of the dragon. Going pretty fast, having fun, but not dragging knee or taking risks. We caught up to a slow as molasses Jeep Wrangler so we stopped at a pull off for about 5-10 minutes and then got back on. Probably less than a mile later I highsided on a lefthander. I estimate we were about 8-9 miles through the Dragon from Deals Gap. It was right after you passed the second scenic over look where the photographers hangout (they did not distract me or anything). I think it is the one that overlooks the dam. I came through the righthander past the overlook ok, but took a bad line through the following lefthander. I got concerned about going wide, of course made the noob mistake of looking over at the edge of the road instead of through the corner, and then at the end when it really seemed like I was not going to make it rolled off the throttle (I don't think I pulled any brake). I of course went wide into a ditch and highsided. I was probably doing 35-40mph through the apex and maybe 25mph when I went into the ditch since I had let off the gas and it was an uphill corner.
I am completely ok. The gear I always wear did it's job. (Thank you, Teknic and Icon) Not a mark on me, just a little soreness in my right elbow and shoulder. God was watching out for me yesterday. I'm feeling it a little more today with more soreness in the shoulder and soreness and stiffness in the back and base of my neck. I've taken spills snow skiing that did worse. I'm glad I had the sense to kind of roll with the bike and did not try to stick out a hand or leg. My Teknic Supervent Pro jacket is still in great shape and just needs a washing. My Icon Airframe helmet has some light scrapes on the right side and a broken rear airfoil but that is designed to break off. Structurally the helmet looks ok but I will be replacing it as a precaution.
The VFR (6th gen) suffered some damage, I actually cracked the crankcase cover (which caused a slow oil leak), broke off my windscreen, cracked my tach cover, and bent my key (I think I did all that with my head), plus some cosmetic damage to the upper front cowling (small crack and scrapes) and right side fairing (all scratches and scrapes). I will also need to replace both the front brake lever and rear brake pedal (they both got bent but are still useable since I bent them back some) and the right side frame slider. The case cover and frame slider took most of the impact and everything else was in pretty good shape. (Thank you Motovation)
After we got the bike back up on the road and moved it to a safer spot I took about a 10 minute break to let the adrenaline subside and let the light shakes go away. The engine started right up and sounded good and there was no damage to the front forks or anything else. I was not nervous at all about getting back on and riding back. I just took it real easy since I knew my small oil leak was dripping oil onto the right side of my rear tire and I was not 100% sure if there was any other damage that might affect performance. Mentally this crash hasn't shaken my desire to ride at all. Half way back to Deals Gap I was wishing there was no oil leak and I found myself wanting to go fast again.
I was able to nurse it back to Deals Gap where some super glue (no joke, thank you Krazy Glue) and some redneck engineering fixed my cracked crankcase cover/oil leak and I was able to ride the bike the 100 miles back to the cabin near McCaysville (we were staying with some friends there for the weekend). I did leave my destroyed wind screen on the Tree of Shame.
Lessons Learned:
1. ATGATT - The armored gear and quality helmet saved me from any significant injury.
2. Even if you have been riding curvy roads all day, if you stop to take a break, even a short 5 minute break where you don't shut off the engine or get off the bike, take it easy getting back into the corners. It takes a few minutes/miles to "dial yourself back in", "get back in the groove", "find your rhythm", etc. The corner that got me was not all that tricky and I had run many like it at faster speeds just 15 minutes before. Taking that short break and then jumping right back onto the Dragon at the same pace that we were using before with no "warm up" time is why I believed I crashed. I had taken some less than perfect lines through previous corners and never felt comfortable at all in the corner where I crashed.
All in all, I still had a blast yesterday. It really was a great day of riding. I'm ok and the bike is operable and repairable without needing major work. I have some pictures that I will post tomorrow. If anyone has a 6th gen rightside crankcase cover, rear brake pedal, or windscreen for sale, please PM me. I think I make go with some aftermarket clutch and front brake leversand replacement Motovation frame sliders. I am going to try to repair the damage to the fairings myself.
Lessons Learned:
