Mounting options for Givi top case?
6 posts Started 16 Nov 2010 Last recovered post 10 May 2011 Wayback Machine snapshot 27 Jun 2013
Wayull, it happened again. A mounting tube for my Givi top case broke. yeah, i guess I do tend to overload the thing... a wee bit. I am at work now, can't check my receipt, but looking at the Givi web stie, I'm pretty sure I have the 257FZ.
I could replace it with the same model, but that's starting to look like a time bomb. Is the Y161 a beefier option? (Granted I don't have side cases, but that's ok. Ugly, but ok :biggrin: ). Are there aftermarket options that mate with the Givi mounting plates? My mounting plate and case are fine, so I'd rather not re-invest in a whole new system.
Thanks guys - Aram
I got one of KandianKens racks that he made with the heavy gauge metal. I dont have the 5th gen anymore so its availible - PM me if your interested.
looks like this one but more robust
Other Side
pillion view seat can be easily removed with rack and bag installed
Mini Givi hardbag with universal mount plate
KKens 5th Gen luggage rack
that smaller one cracked so Ken made me another one with a lot thicker steel - but I only got to use it once, then removed it to put on my wing rack for the triple bag system. It was never used again.
Heavy duty kken rack
newer thicker steel
Are the 5th gen Givi top case racks that fragile? I'm thinking about getting one of those 257FZ racks, but hope it doesn't break with the weight of a pillion pressing against the top case as a backrest.
Evidently, yes they are. I do load mine up from time to time, moderately heavey camera gear, or a stuffed-full bag of groceries. That's about it, though. I am not very impressed. YMMV, obviously.
Aram
Aram
I will disagree with you guys on this one. I have the Givi monorack and it has worked flawlessly for the past three years. I load the crap out of it with my Givi E52 in addition to the saddlebags (Oxford Sports) and the tailbag all of which is strapped to that monorack. With that being said, I have managed either over-torque or stress crack the frankenbolts (or combos of both) which caused cracks in the rear cowl near frakenholes. Easy repair with dremel and fiberglass. That was two years ago and my rear cowl is still holding up well. Just thought I would chime in with a positive experience from my Givi setup. :fing02:
End of thread · 6 posts recovered Wayback Machine snapshot 27 Jun 2013
