Anybody have a set of the slide pin stoppers that are needed for the job (at least 4) that I could borrow?
Thanks in advance,
Greg
[image: View Post]BaileyRock, on 27 December 2010 - 01:02 PM, said:
Personally if it has less than 30-40k miles on it I wouldn't bother. :blush:[image: View Post]BaileyRock, on 27 December 2010 - 02:40 PM, said:
All good Greg and thanks for sharing your findings! :fing02:[image: View Post]MapMaster, on 27 December 2010 - 01:54 PM, said:
I'm aware of the pita factor, but just because it's hard/expensive to do, does not mean that it should not be done.[image: View Post]MapMaster, on 27 December 2010 - 01:54 PM, said:
I'm aware of the pita factor, but just because it's hard/expensive to do, does not mean that it should not be done.[image: View Post]hlf, on 28 December 2010 - 10:39 AM, said:
[image: View Post]MapMaster, on 03 January 2011 - 10:33 AM, said:
finished the initial check.[image: View Post]BaileyRock, on 03 January 2011 - 01:55 PM, said:
finished the initial check.[image: View Post]MapMaster, on 03 January 2011 - 06:31 PM, said:
[image: View Post]swimmer, on 03 January 2011 - 09:28 PM, said:
So, how would your rank the 6th gen valve inspection on the pita scale?[image: View Post]MapMaster, on 04 January 2011 - 12:01 AM, said:
So, how would your rank the 6th gen valve inspection on the pita scale?[image: View Post]budd44, on 04 January 2011 - 09:58 PM, said:
This is great info. I'm getting ready to check the valves on my '02 with 16k miles. If I don't check the VTEC valves, can I measure clearance on the others without removing the cams? If they were in spec it would provide some piece of mind while avoiding the extra tools and effort. This is my first post, so please excuse if my format is poor.[image: View Post]swimmer, on 04 January 2011 - 02:12 PM, said:
So, I guess you don't want to do mine then?[image: View Post]BaileyRock, on 05 January 2011 - 04:04 PM, said:
