Just noticed that one of the throttle cable (comes in a pair) had the rubber housing sheared, exposing the metallic lining within the outer rubber shell.
This must have been caused by the constant abrasion of the throttle cables again the fairing/headlight stay.
Is there any adverse impact of keeping the throttle cable as it is, with the metallic sleeve exposed?
Are throttle cable replacement a lot of work? Does the fairing and tank needs to go off first?
