New Member, quick question
11 posts Started 19 Mar 2011 Last recovered post 22 Mar 2011 Wayback Machine snapshot 22 Mar 2011
Hey there,
Just picked up a white 2006/ABS/Bags.
I'll post a better intro and pics later, but I have a quick question. Does the Ram mount RAM-B-309-2U work with the bike? I had them on an Aprilia and liked the location.
http://www.ram-mount...85/Default.aspx
Thanks,
Walter
Attached thumbnail(s)
  • [image: Attached Image: ScreenHunter_01 Mar. 19 14.02.jpg]
I'm pretty sure that it does. I have one on my 5th gen, but I dont know the part number. also on at least a 5th gen, it works on the front gas tank hold down bolt holes.
Timmy's looks a lot like mine. Not sure if there will be room for that second ball though...
[image: Attached Image: ramball.jpg]
[image: attachicon.gif] ramball.jpg
+1 Thats one I got, like it a bunch !!!!!!!!!!!!!!!
I believe the tank mount ball (which I have and like very much) is the RAM-B-231 at the site you linked to in the OP. Toss the U-bolt and get slightly longer tank bolts. I couldn't find black bolts though.
RAM-B-231
Brian
[image: View Post]wpbarlow, on 19 March 2011 - 01:11 PM, said:
Hey there,
Thanks,
Walter
I've got the single ball version of it mounted on mine. I don't see where the second ball would create any problems.
Thanks for the responses; I'll be ordering today.
Walter
I have the two ball version. 'Coz two balls are better than one.
It mounts on the tank or on either reservoir.
I used M6x40 cap head screws from McMaster Carr. IIRC a box of 25 was ~$2.
Hey there,
Thanks,
Walter
I just mounted the single ball version on my 2008.
First I tried to remove the back side of the clutch lever clamp and replace it with the RAM mount.
The supplied bolts were way too long. Then I decided to leave the clutch clamp intact and put
the Ram mount up against the rear half of the clutch mount. The supplied bolts were still about
a half inch long so they needed cut down.
Looks and works great. I replaced the 3" arm with a 2" arm which seems to work a lot better
with the Nuvi 550.
Now I need to order the Powerlet steering head outlet and the mini-usb power pack.
End of thread · 11 posts recovered Wayback Machine snapshot 22 Mar 2011
