[image: View Post]coderighter, on 07 April 2011 - 12:33 PM, said:
I had removed my PAIR only because Dynojet had told me that I needed to for the Autotune to work correctly. Later I decided to test it's function. I connected a light to the PAIR electrical plug and went for a ride. I found the PAIR circuit was only active when the throttle was closed and when the temp was below 168(ish)F. Once the bike hit 169(ish), I never saw the light come on again. Since the bike doesn't go into close loop until it's up to temp, that would make sense. The PAIR would never affect close loop operation. With further research, I found the PAIR is only to help reduce emissions during warm up. At the same time it helps generate heat in the CAT and also heats up the O2 sensor to help them both operate correctly. So what does removing it do? Well after the bike is at operating temp....nothing. However, it may take the bike it's self a little longer to get to that temp. The reason I left mine off? One less thing to malfunction.
While the snorkel and flapper are there to lower intake noise, their main purpose is maintain intake viscosity at small throttle openings. The flap doesn't open until the bike can use the 'extra air'. Disabling the flap doesn't increase the overall volume for max power, at full throttle, and a RPM at which it's needed, the flap opens anyway. Disabling it and removing the snorkel can only hurt low speed torque.
The fact that the intake sounds louder, mentally tricks our 'butt dyno' into thinking we're making more power.
Think about it, even if you could find a way to get more air in, because the bike has no air flow metering, you would only make the bike run leaner than it already is. You would need to dynotune or Autotune to see any results.
Personally, I feel the only way to increase airflow without affecting low end torque is at the air filter, but that too would require some type of re-tuning. I'm guessing after a little dust buildup on the stock filter, (with its screen and metal mesh) at full throttle the two 'intakes' will flow more air then the filter itself.
My 2cents.
So based on your findings the exhaust reek experienced by
whiteboyslo would only be happening while at idle or when the throttle is closed and prior to reaching operating temperature.
It seems like you would have to spend a lot of time idling with the throttle closed and the engine at less than operating temperature to cause one to reek of exhaust fumes.
I don't do much riding in traffic and very seldom idle the engine. That might be why I have never noticed any exhaust odor.
The fact that you didn't mention any exhaust odor either makes me think that the results are somewhat varied.
Interesting discussion even if I don't understand much of it. :mellow:
