[image: View Post]Skids, on 18 May 2011 - 01:46 PM, said:
he VTEC transition is no longer an issue since the '06 model, however it's the VTEC itself that I find the issue. From arouund 4.5k rpm to 6.5k rpm, there just isn't very much torque and it's a lot less than the Fi, which has oodles of pulling power even in 6th. The bike needs to be in the VTEC range in order to deliver the same/more than the Fi. And that is the issue with the engine....along with poor fuelling low down. A development of the Fi engine which was emission-compliant without resorting to the VTEC would be a fantastic engine.
Actually Vtec transitions issues are very subjective and opinionated and seem to vary Widely from bike to bike no matter the year! I personally have Over 100,000 miles on VFR800's alone and still have a 5th & 6th gen in the garage. I've never had an issue with my 02 vtec over the last 83,000 miles and if you read in this thread alone there are complaints about 06-up issues still.
Several points to consider on 5th gens alone. There are basically Two versions of a 5th gen, 98-99 and the 00-01.
The 98-99 is considered the best versions of the 5th gen as they are the lightest, have Larger header pipes(43mm vs 41mm), no Cataletic Converter and use a different Fi system than the 00-01 VFR's. These factors No Doubt make the 98-99's provide stronger numbers throughtout the rpm range.
Secondly The choked down header tubes, Cat and different mapping along with more weight slowed down the performance of the 00-01, these same changes alone with Extremely LEAN fueling only help nurtered the Vtec a little more. It is Mostly the extreme Lean mapping that hurts many Vtec's smoothness and why a PCIII can make it So much better. Even though mine is still stock.
The Vtec has the Best Chassis to date and yes a 98-99 motor would be sweet in a 6th gen chassis, but it wasn't an option! BTW You will also find most Vtec owners happy with their bikes like myself.
Back to the topic which was "ABS or Not" on a 6th gen as every 6th gen has Vtec!
It was Not a 5th gen Vs 6th gen question.
Yes, get ABS if you can! :fing02:
PS i lug the hell out of my 02 and rarely see Vtec to haul butt in the twisties unless I really want to Rip-It! :fing02:
