[image: View Post]tx_vfr, on 27 July 2011 - 02:16 PM, said:
[image: View Post]SEBSPEED, on 27 July 2011 - 08:54 AM, said:
Sounds like you need to clean your calipers and pistons - your pistons are sticking. Also, the FSM is wrong on the bleed order. You need to bleed the proportion valve and both of the rear caliper points with the rear brake pedal.
Did you remove the rear caliper and set it on top of the rotor like the book says?
The vacuum pump is nice for getting fluid into the lines, but you'll get a much firmer lever feel by bleeding with the lever.
Tapping on the lines is a great way to loosen trapped bubbles, however, you should start tapping at the caliper, not at the master.
Did you run the fluid out of the front master at any time? If so, there could be air trapped at the master banjo and you'll need to "burp" it. To do this you need to remove the master from the bar and tip it slightly to make the actual reservoir the high point instead of the banjo. Then very gently and only slightly squeeze the lever to release the air bubbles into the reservoir.
Speed Bleeders make things very easy(once they've been properly installed).
I did not remove the rear caliper.
From my understanding of the FSM, and its pretty un-clear, you remove/tilt the LF caliper. I did that, but didn't remove the rear caliper.
I did not run either front or rear MCs out of fluid.
I've bled the brakes w/o the vacuum pump in the past and while it helped, it didn't solve the issue. Was hoping a little extra help would do the trick.
[image: View Post]Goosechef, on 27 July 2011 - 11:20 AM, said:
Perhaps you can leave her at home?
Lost me on that one...
You said it is worse with your wife on the back. Perhaps leaving her at home would help. :laughing6-hehe:
