Hey all, my clutch is starting to slip (or maybe not read some previous forums on here) and just wanted some opinions. Bike is good through the low gears but once you get to like 5th 6th gear around 90-95ish (mph) and roll on the throttle hard it just revs up really high and nothing happens. If your a little nicer on the throttle you can get up to 135, havent tried getting it all the way up this year yet but I'm assuming it can still make it there.I've owned it since around august 2010 and the bike has 26xxx miles on it or could that be 126xxx maybe (it's a 1995). I run amsoil sythetic 10W-40 in it and havent had any issues before. After reading some other forums on here I might try the deglazing method that was discussed, but would a new cluch feel drastically different than the stock one in good condition, like would it engage better and pull a lot nicer? Any advice/opinions or comments would help thanks.
Also on a side note both of my rear blinkers are out idk if the both went out at once or died separately so I cheked that they were connected (they were), but the brake light still works. Think they're both dead or maybe a wire issue?
