Brake Modulator Install Help
6 posts Started 6 Apr 2012 Last recovered post 3 May 2012 Wayback Machine snapshot 8 Jun 2012
Installed :) I Cut Green/Yellow wire to top brake light, wired in modulator, connected modulator ground.. easier than I expected.
Question: Does splicing into one of the lights mean that only one of the lights is affected by the flasher? I'm interested in installing a brake modulator myself but would like for both bulbs to flash in unison.
I too am interested in a brake light modulator but I'm finding that there are several available and that the prices vary. I see the Signal Dynamics XP Back-Off is popular http://signaldynamic...emart&Itemid=77 there's the one above which is half the price http://www.kapscomot..._p/pw-13001.htm and I also found this tiny modulator http://www.xdponline...402c882d3247583
What are my fellow 6th Gen VFR lovers favoring? My primary criteria are; relatively easy install, long life of flasher unit, and being able to have both brake bulbs flash. Thanks for any advice.
I can speak to the Signal Dynamics.
Both bulbs flash in a Wig Wag pattern for XXseconds then Three longer simultaneous flashes, then solid until the lever(s) are released.
Installed probably 3 years ago. Hasn't failed or burned a bulb.
Don't forget to headlight Mod.
There are 2 patterns you choose between at installation of the SD wig wag.  Really easy to install on 5th Gen.   Connecting such tiny wire gauges and length of wires were only issues.
Sent from my DROID RAZR using Tapatalk
End of thread · 6 posts recovered Wayback Machine snapshot 8 Jun 2012
