[image: View Post]Tamworth, on 15 April 2012 - 08:13 AM, said:
[image: View Post]spud786, on 15 April 2012 - 07:48 AM, said:
I think its either chemically welding the thermo or changing the bimetal properties. I just cant believe Honda could have repetitive batches of bad thermos, over a ten year period.
It is just happening far too often and the Coolant is a common denominator, which my bike has not been exposed to for any length of time, and never had the issue.
Thermostats are wax units so there's no bi-metal elements. They are not produced under particularly exacting tolerances, some go for ever and some fail early. It's pretty unlikely that any particular coolant product is causing damage to the thermostat. Coolant can not "chemically weld" anything or change the properties of any type of metal.
Reports of thermostat failures will obviously be concentrated on a model specific forum, but this doesn't indicate a recurring failure in the VFR line. Honda uses the same coolant in all their bikes and there really is no record of a common problem.
Silicates are typically used for cleaning purposes, Honda has no silicates, so cleaning is done via other chemical properties, if cleaning is insufficient, a chemical weld can take place between two moving parts. The vfr also runs hotter temperatures than many others, this may also play into the combination of Failure. But the failure rate of vfr thermos is wide spread and over a long period of time.
We can debate this, but If I got a new vfr, that Honda coolant is gone just as I did with my present vfr, cause changing a Thermo is highly undesirable. I can understand your running the honda coolant and want to justify or rule out. I can only say, Ive never had the issue, and the Honda coolant was gone before the first 2000 miles. Ive not regretted it one bit. I have followed the Honda Thermo issue for years, I see no reason to change my thoughts of this common denominator, regardless if I know the exact detailed reason , the coolant is Highly probable though.
