So my bike's running extremely rich lately, so much so that it burns your eyes and throat when it's cold. Also, when it's cold, it spews what appears to be white smoke. The 'smoke' definitely has a gas-stink to it, and it goes away once the bike is up to full operating temp. It's quite noticeable at idle, but makes a full plume with a blip of throttle. It had me worried it may be a coolant/head gasket issue, but there are no other telltale signs (overheating engine, low coolant, milky oil, etc).
Engine-wise, I've done the following to the bike:
K&N
De-snorkeled
PAIR block off (plugged the hose for now. Still need to install the A&A plates)
Power Commander III w/ original Cozye map
O2 cheaters (the ones that come with the Power Commander)
2 Brothers exhaust
The most recent of those mods are the Power Commander and the PAIR block off. It would seem the issue would be linked to one of these since it started running rich about that time. The bike runs GREAT (unreal, actually), but the meter on the Power Commander stays buried in the low end at idle ( - FUEL) and only comes up to mid way with any throttle. If it makes any difference, I pretty much ALWAYS run 91 octane.
If the consensus is that this is perfectly normal for the cozye map, then OK. But it just seems a bit much.
Mike
K&N
De-snorkeled
2 Brothers exhaust
Mike
