'02-'05 Power Commander III Users?
1 posts Started 7 Oct 2012 Last recovered post 7 Oct 2012 Wayback Machine snapshot 2 Nov 2012
The temperature was 30 degrees this morning so I have too much time to think.
Those of you that have '02-'05 machines and are running the PC III: (Dyno developed map users excluded)
1. Have you tried some of Dynojet's maps for the PC?
2. Have you tried Cozye's map for the PC?
3. What did you find for benefits or faults with either?
4. Which map are you presently using?
5. What is supposed to be the benefit of the Cozye map over the maps available from Dynojet?
Kind of generic questions.
Based on many recommendation here, I went right to the Cozye map when I installed my PC III USB and with a few tweaks, I have been happy with it. Never used a Dynojet map. Bike isn't perfect, but it ain't too bad.
Probably shouldn't fix what ain't broke, but.............
Since Dynojet supposedly developed their maps on a dyno, it seems like they should actually be better.
That doesn't seem to be the general opinion and I was curious why.
I have a 2004 with a K&N, stock exhaust, PAIR valve and flapper valve disabled, O2 sensor eliminators, PC III USB with Cozye map that I have somewhat modified if anyone wonders.
End of thread · 1 posts recovered Wayback Machine snapshot 2 Nov 2012
