Dear All,
Would anyone have the color codes for RWB of the 2007 VFR? I want to paint hard bags to match the color of my bike and I cannot find the color codes.
Cheers and thanks!
CElias
Well, this probably is not much help. But the label under the seat says VFR8007; Color - NH - 341P; Code - NH 341 H. Since we have three colors, not exactly sure what color this is. I could not find it in manual either. Call to dealer may be in order. Sorry I could not be more help.
That code just refers to the predominant color of the bike, which is called "Pearl Fadeless White", apparently. I'm not familiar with that particular color scheme, but the way I've found other colors for other mult-color Hondas in the past was to look for a specific, single-color painted part, e.g. the front fender, and see how the Honda Parts Catalog describes it (usually, the color code for the part is provided). The code for the white you have already, but the red stripe may not be paint at all (it may be a decal?), and if not, then there would be no Honda paint code for it. Good luck.
R101CU Candy Glory Red
PB308M Pearl Spencer Blue
NH341 Pearl Fadeless White
I believe the red is a decal on the plastic, but paint on the tank. Each brand of paint will have a different paint code, from what I understand, and some of the colours may require base coats and top coats to achieve the right colour. Good luck!
The blue does not require a base coat/ top coat I believe. I just purchased some "Spencer blue" touch up for my '07 RWB. the dealer was getting confused when I was trying to order the white and red and said the same thing about having to apply the base/ top coat.
Why not go to Colorite's website and get the paint from there? Yes, you will pay an arm and half a leg, but it WILL be a match.
You've never heard them referred to as "Colorwrong", then...? :sad:
