Stator to rr connector question
7 posts Started 8 Nov 2012 Last recovered post 10 Nov 2012 Wayback Machine snapshot 21 Jun 2015
The connector between my stator and R/R got a little hot and melted, so am going to do away with plugs.
Could anyone tell me if the stator wires need to be connected across to the R/R wires in the same order/arrangement as if I were using the OEM plug?
Why would you try anything else?
I don't know, just out of curiosity, and if I was to somehow mess it up and lose the order... I do kinda have a knack for doing that...
Yellow wires can be connected to the R/R in any order. - Suggest to use a Metripack 630 connector.
http://www.pcsconnec...tripack630.aspx
Knute,
It does not make a difference. Look at the test procedures for the stator and you will see that testing between all 3 wires from the stator should have the same output. The RR just takes the output from all 3 wires and converts it to a usable voltage for the bike. So, it does not matter which yellow wire from the stator goes to which yellow wire to the RR.
Huntingguns and mello dude... Thanks for the replies fellows, much appreciated!
What did you use to get a good solid crimp on the wires? I know crimpers are sized for particular gauge wire. Is there a particular crimper you used/liked? Or would any for "x" gauge wire work OK?
Not point is half-assin' it, solder those joints.
End of thread · 7 posts recovered Wayback Machine snapshot 21 Jun 2015
