Superlite Steel Rear Sprocket
10 posts Started 26 Feb 2013 Last recovered post 27 Feb 2013 Wayback Machine snapshot 18 Sep 2017
Ordered one for my 6th gen, but it will also fit from 1990+ VFRs, I like the powdercoated black look and for fun decided to weigh it at work. It came in at 1.4 lbs.
Not bad for $54 shipped.
I'm pretty sure the one I pulled off my bike weighed at least twice that much.
that is all. :)
91talon
Only if they have separate part numbers - one for 3rd-5th Gen, and one for 6th Gen. For some reason Honda changed the sprocket bolt PCD just enough that they are not interchangeable.
I just looked them up at Sprocket Centre, there are separate listings but both have the same part number? I'd ask the question before I ordered...
6th Gen, part no. SL10607R
http://sprocketcenter.com/index.php/street-sprocket-applications/honda/vfr-800f-2002-2009/oe-sprockets/superlite-black-530-conversion-steel-rear-sprocket-honda-vfr.html
5th Gen, part no. SL10607R
http://sprocketcenter.com/index.php/street-sprocket-applications/honda/vfr-800f-1998-2001/oe-sprockets/superlite-black-530-conversion-steel-rear-sprocket-honda-vfr.html
The Phantom
91talon
It has more than one set of holes drilled for the different bolt patterns.
Much like a rim for a car that has both 4x100 and 4x114 bolt patterns on the same rim. Reduces production costs, as you only need to make the one piece to fit multiple applications. (as long as all other dimensions are the same anyway.)
Also, there is a definite difference in bolt hole diameter, now that I look at it.
Edited February 26, 2013 by 91talon
I knew they did rotors with different hole patterns, but not wheels.
From the website:
*This part number is double drilled with two bolt patterns so it fits all VFR 750/800 models from 1990-2009.
At least now I know where to find a steel 520 for the triumph that's in stock and not 3 months out. I'm not familiar with Superlite sprockets. I was going for an AFAM front, forget who the rear was.
YoshiHNS
From the website:
They are made by Drive, and I haven't read any bad reviews about their stuff.
Edited February 27, 2013 by 91talon
I have a set of Superlites (16-43), and DID gold X-ring 530 chain from Drive Systems. Well over 20K on 'em, and no signs of abnormal wear despite moderate abuse (dirt, rain etc.). Put a duplicate set on viffergyrl's 5th gen recently. Will replace my current set with same when it wears out.
1 lb 4 oz is lite for a 530 steel sprocket... that compares well with Mr.RC45's HRC aluminum sprocket
and my 43 T 525 trimmed and drilled steel modified sprocket at 1 lb 2 oz...
[image: gallery_3131_51_28717.jpg]
[image: gallery_3131_51_14811.jpg]
Whoa... yeah, I'm not sure what the weight on this one would be if I were to trim it even more in the areas that aren't bolted.
91talon
The Phantom
91talon
Good stuff, smart thinking by the manufacturer.
I have a Chain Gang (Australian manufacturer) steel 45T rear sprocket, their current VFR styles are pretty nice:
[image: sprocket_5_blue.jpg]
I like it.
End of thread · 10 posts recovered Wayback Machine snapshot 18 Sep 2017
