Help, Need Chain Lube Advice...
19 posts Started 30 Mar 2013 Last recovered post 4 Apr 2013 Wayback Machine snapshot 9 Apr 2013
Hello again guys, I just installed a new chain and I don't know what lube I should stick with.
With my previous chain I was using PJ1 Blue Label lube, i can't tell how good it was but my chain would quickly look nasty and that thing is very sticky, dunno but I don't think that's good...
I just got a can of Maxima Chain Wax, never used it and i really don't know anything about chains. I just want to get the longest life out of this new chain as possible.
Should I stick with the sticky pj1 or should I switch to the chain wax?
Btw, the chain Is brand new and rode about 30 miles, should I lube it already or the grease film that comes with it is good for the rule of 500 miles???
I hope you get some serious answers but with this thread title you will at least get some laughs. Good luck and I would lube the chain now but can't advise you as to the best lube but I bet you can search this site and find it. They will also tell you to install a Scott's oiler most likely
Again good luck
I tried Chain Wax many years ago and maybe it's better now, but it was poop then. I use 80-90 gear lube and the Hawke Oiler. It works well, but the rear wheel does get a bit messy, but since it's just lube it cleans up easy. Lots of choices out there.
Chin lube??
Think you got the wrong forum there bud!!!
Now as for CHAIN lube, I use Kraaft spray on chain oil... yellow lid... every 500 km and/or after rain.
  In the last 20 years Ive bought two cans of chain wax, the second time was cause I forgot I bought the first, imo it sucks clogs up the whole chain, so Id use the pj1 over the wax. If those are the choices.
I've been using the chain wax for the last year. I spray it every 500 mi & clean it with wd-50 every 1500 just like the manual says. It does pick up quite a bit of crap & is hard to clean off.
I hate chain wax, because its a dirt magnet and everything sticks to it. -- Suggestion is to go to a dry film type like Pro Honda HP Chain Lube (red can). It has Moly and Teflon in it. - Clean chain, spray on. Let sit for 20 minutes and its dry. No tackyness, and generally chain stays clean.
(Holy shit, I agreed on something with spud. Did hell freeze over?  :wink:  )
:cool:
I use a Teflon lube, found it a Lowes.  Have to say, you gotta do more than what I do though...
I really never lubed or adjusted the chain much after installing it about 10k miles ago, and after many thousand miles of it running loose, it has seriously bad wear on the rear sprocket.  The dip in between the teeth is seriously deep, and if the chain is properly adjusted, the links will hang onto the sprocket.
Oh, well, I can use it as a teaching moment for the guy at work who comes over frequently when I do mechanical work, so he feels more comfortable working on his bike.
A german MC mag (Motorrad) did a test on chain oils, measuring various charactaristics. I recall that the S100 White stuff came out on top.
I used it on Gradus' 6th gen during TMAC.
I have a Scotoiler fitted on my 4th Gen.
LOVE this stuff, chain is super quiet and eats this stuff up. If you do it after a long ride and let the lube sit over night there is NO fling-off. Keeps your chain, guard, wheels, and swingarm looking good, and your chain loves the super slippery teflon  :fing02:
  • [image: poop.jpg]
I've used the same stuff from day one on my '04.  It has close to 23K miles on the original chain and sprockets and everything still looks good.
That looks like the Teflon stuff I use.  When I remember to, at least.  I get a bit over 20k miles/chain with occasional spraying of the lube, and a very, very occasional cleaning with a "Grunge" brush.
Mostly highway miles, commuting.  Very occasional rain here in TX.  Just got some rain today, so probably will hit up the chain tonight with some lube when I get home.  Unless I'm really tired.
+1. I switched to this stuff at the end of last year. Was using 90 weight and it really makes a mess. Noticed an immediate improvement after doing a thorough cleaning and applying the Dupont. Chain is quieter and smoother.
Available in a squeeze bottle now.  I bought some hoping it will be easier to apply with no overspray.  Easier to pack on trips.  If spring ever gets here, I'll give it a try.
[image: 036121191860lg.jpg]
+1 Dupont Chain Saver (since they discontinued the blue can stuff)
Well, I can tell you it works.  It is more convinient to pack on trips, however it is much faster to use the spray.  I don't mind overspray for the simple fact that with a spray can I can aim, spray, and spin the wheel by hand.
(I take the squeeze bottle on trips, normally.)
BTW, how's Rochester holding up?  Sounds like you are still buried under snow?
Snow is mostly gone, but it is cold with a biting wind.  Roads are covered in salt.
I used to live there, hated waiting until a good rain to wash that junk off the road.
Then again I snapped a clutch cable getting my bike out of a barn, and rode it back to my school on partially snow-covered roads.  Not my most intelligent move.  :goofy:
150k+ miles on different bikes, never "cleaned" a chain. Slap some gear oil down every 600 miles or so...the good O-ring chains last 22k-25k miles...then replace sprockets and chain...rinse and repeat @ the next 23k miles..
End of thread · 19 posts recovered Wayback Machine snapshot 9 Apr 2013
