Sorry for the long story, but...
I had my 2004's coolant flushed and replaced last summer. Ever since then it seems to run a little hotter than it ever had - to the tune of 2-5 degrees (F) most of the time. I used to see 168-170 most of the time, but since the flush it was 170-173. It also seemed to me that the fan was coming on at a higher than usual temp, but otherwise working normally. I asked the shop mechanic about it but he said the temps were within normal range. He kind of alluded to "setting" the fan starting temp to a higher temp, but I've never heard of this.
Running a few degrees hot is not a huge deal for me, but is a little annoying because it means it will run that much hotter in city traffic, etc. and may cause a bit more wear and tear on the fan and cooling system.
I should also mention when the bike started running hot after the initial shop flush I decided to do my own coolant flush, but botched it and killed my fan switch when coolant spewed out of the filler opening on the right front of the bike. :sad: Even after the switch was replaced (and coolant flushed again) at the shop, the bike was still running a few degrees hot. I can live with it but I also know it's not normal.
Also, I've been running slightly heavier motor oil (15W-40 and 15W-50) since last summer to alleviate front CCT noise, which works OK most of the time. I thought maybe the heavier oil might be causing the motor to run a bit hotter than usual.
Last night I changed my oil and filter, and used 10W-40, and today was seeing temps of 173-175 on the open road at 73-75 (F) ambient temps. I should also mention I slightly overfilled the oil last night. Last night it was at the top mark (after filling, running, and then topping off), then today after a 50-mile ride the oil level is 1/8" to 1/4" over the top mark. Not a big deal and as far as I know it's not a problem to leave it as-is.
Questions:
-Has anyone else ever had an issue with their 6th gen. running a little hot under similar conditions?
-Is it possible to get my bike's operating temps back down to what I know was the norm for 5 years?
-Is it even plausible for a fan's start-up point to be set to a certain engine temp?
Thanks in advance for any help or advice! :smile:
