Hi all
I've been working on how to get the low speed, throttle position from 0 to 4-5%, throttle response better on my 2010 VFR800 Vtec.
There is a huge post over on Bikers Oracle where one member has been saying for a long time that the flat syncing of the starter valves, as shown in the Gen 6 service manual is not correct and they should be synced similar to the Gen 5 and earlier VFR's.
This is where 2 starter valved are set at +10 mm/hg and the other adjustable one set at -10 mm/hg, hence staggering how the vales open in the early throttle opening (0 to 4% by what Honda UK have said).
I've been testing this theory over the past few weeks and changing the steps between the offsets until I've now got to about +/- 20mm/hg between them.
With the valves set like this, the low speed response is amazing.
I must say that I have a Rapid Bike 3 ECU fitted and have built a good map for it over time using a wideband O2 sensor and data logger, so I've been able to remove the 3000/4000 rpm stumble and lessen the Vtec kick in pretty much.
Back to the starter valves.
I've not stuck with the exact process that the Gen 5 uses and have set valve 1 at +20, and valves 2 and 3 at -20, with valve 4 (unadjustable) used as the datum at zero.
I feel that this gives a more varied throttle application off closed as the valves with a higher vacuum reading when synced will stay closed longer. So I think I get cylinders 2 and 3 applying power first, then number 4 kicks in, and lastly number 1. A much more staged application of power until you are at 4% throttle, then the butterflies take over.
What I can now do with the throttle, at no load in neutral, is bring the rpm up to 3000 and hold it, raise it to 3500 and hold it, drop it to 2500 and hold it and then go back to 3000. All quite fluidly.
In the past, when I tried the above, you could hold the 3000, raise it to 3500, but when trying to drop to 2500 the rpm would drop all the way and you couldn't get any smoothness.
It's completely different now. Rolling the throttle on thru a corner or round a roundabout is just soooo much smoother.
As the starters only affect the throttle from 0 to 4% on the tps, this seems to have no effect on power or cold starting, but it make a huge difference from a closed throttle.
Below is a photo of the end settings on my vacuum gauges as an example.
[image: post-25941-0-50025900-1399707226.jpg]
Edited May 10, 2014 by HighSideNZ
