Will the 94 carbs fir a 1990?
Carbs
different carbs.. they will bolt up, but I believe the 3rd gens's were 36mm, and the 4th are 34mm... or something like that.
Thanks Burns, so only difference is size.
Ladies and Gents,
I have re-inherited my son's 1996 VFR-750. Has not run in at least two years. I want to remove the carbs and have them cleaned / rebuilt.
Can someone point me to the correct thread or forum?
Thanks much in advance.
Cheers,
Mike Shelton
Stafford, VA
This link isn't for a VFR, but rather an ST1100. The pictures and explanation are great, and I would expect the VFR should be very similar to the ST (except swung around 90 degrees!). Sorry, my VFR has FI.
I got 'em off. Thanks. Will be on the way to the mechanic for cleaning and rebuild.
Mike Shelton
Stafford, VA
