Headlight Harness Question
3 posts Started 7 Oct 2014 Last recovered post 11 Oct 2014 Wayback Machine snapshot 12 Oct 2014
Okay... my right headlight decided to stop working.  Upon investigation it appears a previous owner decided to slice and dice the connections.  Beyond repair at this point - the correct connector to the bulb is missing and there is almost no wire left to splice into in any case.
I want to put a new harness on.
I am wondering how tough it is to replace the harness - is it a simple plug and play operation?  Is it easiest to simply remove the entire fairing set?
Finally, is there a separate harness for each side or a single harness for the entire headlight assembly?
This is what I am planning on purchasing:
[image: P1030283.JPG]
As always, thanks!
Oh, and is there anything else I should go ahead and replace or upgrade while I have the entire assembly apart?
Sorry to hear that you are having to undo what the PO did. I don't have answers to the questions about the harness itself, but while you have the cowl off (and yes: I'd be removing both sides and the front, I'd urge you to consider replacing the light bulbs themselves with LED units. Here's what I did, and I really like them (although I wish I had replaced both the high and low rather than just the low beams):
[image: yaB2Cxa.jpg]
I thought I replied... I saw the LED thread and am considering it, but I hate the idea of cutting up a new harness.  IS there a way to mount the LED bulbs without cutting into the harness?
In any case, I like the install you did - it looks very clean.  Very tempting...
[edit:]
Never mind... I see how the harness works.  Much happier to give that a go.
http://www.amazon.co...4 LED headlight
Are these the same light?
End of thread · 3 posts recovered Wayback Machine snapshot 12 Oct 2014
