Thanks for any suggestions
Im using a Throttlemeister but seriously considering switching to an actual electrical cc. IIRC Audiovox was making one that some members had installed. I would like to hear their thoughts as it was pretty expensive and labor intensive to install.
I just put a Go-Cruise on mine not long ago. I have not had a chance to use it much yet but I like it so far. My Dad's old BMW has real cruise control and I do have to say that I like it!
NEP throttle lock. Not fancy but gives the right hand / wrist some relief. They also easily clear the tank at full lock. They're about $20 on line or at Cycle Gear.
Didn't Audiovox die a long time ago already??...... So maybe not available anymore new.....
I remember the CC from them. It was basically a rehash of the same system for cars (just made water resistant) they used to sell at discount department stores like Kmart.
The system from them was designed eons ago, and I remember seeing them even way back in the 80's totally identical to the last one I've seen years later. The system didn't look that bad, but not what you would call technically impressive of cool looking either, with second tier materials and finishes. I guess it worked well enough for most people.
IMO, you'd be better off just using a "manual" CC like the Throttle Meister or similar, as the complications of an electric system will just add burden to maintaining an already challenged electrical system on our VFRs......
Had to have the McCruise on my ST, spent the big bucks and it's been installed now for 6 years. Would NOT do it again. Expensive yes, but that's because it's at the top end of the market. I've had issues with it failing because of our crap fuel here in the States (according to the OEM). The owner of the company is a nice guy and does call you to provide customer service all the way from Aus. but it just doesn't work for me because what's easy for him is difficult for me and he soon looses patience if you don't get it. If only there was shop, or tech. Stateside, it would make all the difference. I'd ride 1000+ miles to have an expert set it up properly.
I had a Throttlemeister on the ST originally and kept it on as a backup. Good thing as it's back in use again because last Sunday when I went out the McCruise was non-functional once again, despite having been torn down and the jets cleaned out just over a year ago. It's becoming an annual event.
I've got a GoCruise on the VFR and I love it. Simple, cheap and it works everytime. When I switch the ST over to a VFR1200 in a few years time I'll go with the Throttlemeister and spend the $900 in change (probably more by then) on other stuff.
Why would the "crap fuel" have anything to do with the MCCruise? Fuel doesn't come in contact with any part of the unit nor it's controls?Had to have the McCruise on my ST, spent the big bucks and it's been installed now for 6 years. Would NOT do it again. Expensive yes, but that's because it's at the top end of the market. I've had issues with it failing because of our crap fuel here in the States (according to the OEM). The owner of the company is a nice guy and does call you to provide customer service all the way from Aus. but it just doesn't work for me because what's easy for him is difficult for me and he soon looses patience if you don't get it. If only there was shop, or tech. Stateside, it would make all the difference. I'd ride 1000+ miles to have an expert set it up properly.
Appologies for my use of incorrect nomenclature. After re-reading the McCruise Repair and Replacement of Solenoids and MCS020 and MCS574 Vacuum Actuators pamphlet, jets is not the correct technical term and I stand corrected. To be specific the Vacuum Solenoid Shuttle was stuck in the bottom of the housing. This required removal/disassembly of the actuator from the bike and cleaning said Solenoid Shuttle with de-natured alcohol. According to the Mr. Tony, the Chief Engineer, owner, inventor, this is caused by the CRAP GAS in the USA. His words,spoken to me via the magic of international long distance phone calling, not mine.
The same thing has happened once again, 18 months after the first time, so I'll be breaking out the de-natured alcohol once more.
I applaud your 15 years of care-free McCruising and wish my experience was similar.
@Club racer
Badly made corn based ethonol (and to a lesser degree, sugar cane ethanol) can leave a gum inside your engine. Some parts of the US are worse than others. The fumes transport this crud to the solenoid shuttles and all it takes is a thin, non-visible coat to stick them in place over winter.
It can be cleaned with pure ethanol and a lint free rag but getting to the actuator on the ST13' is difficult - on something like the FJR13' it's right under the seat.
If you can find space on your bike for the fully electric servo (and matching computer software) it would eliminate this issue. Somewhere not right next to an exhaust pipe would be good. The unit is 2" in diamter, 6.3" long, and probably 1.5lbs in weight - link
steve@mccruise
Hmmm.Appologies for my use of incorrect nomenclature. After re-reading the McCruise Repair and Replacement of Solenoids and MCS020 and MCS574 Vacuum Actuators pamphlet, jets is not the correct technical term and I stand corrected. To be specific the Vacuum Solenoid Shuttle was stuck in the bottom of the housing. This required removal/disassembly of the actuator from the bike and cleaning said Solenoid Shuttle with de-natured alcohol. According to the Mr. Tony, the Chief Engineer, owner, inventor, this is caused by the CRAP GAS in the USA. His words,spoken to me via the magic of international long distance phone calling, not mine.
go cruise for the win on every bike I've tried it on.
I got a "Photon 2" cruise control clamp. $20, very simple plastic clamp and rubber band for grip.
Not good enough grip, though (vibration eases it off in seconds).
I boosted its stiffness with a simple zip-tie through the holes around the other side.
Works well now.
