Manual Tensioner
You'll need two.
Install question. How do I know how to get the proper tension? Does anyone have any install experience? Do I just install then carefully tighten until I feel some pressure, start it up then adjust just until the chain is quiet?
I found this online: http://blog.biker.ie...-tensioner.html
Just a question... How do you keep the threads from leaking oil? Seems like they would just drip, drip, drip? What am I missing? Do you use sealant around the jam nut?
Teflon tape the threads.
Stupid question time. Do I not worry about the cap on the manual tensioner, as there is no way to attach it?
I just looked at the one you purchased, out just bolts straight in. The adjuster bolt head rides against the tensioner shoe. Hope this helps.
I put some APE tensioners into my VTR1000F. To set the tension on this I was advised to look for 5-7mm play (total up+down) in the chain between the two cam sprockets. So you need to get the valve covers off, and in the case of the VTR you also need to unbolt the guide shoe that sits above the chain run between the sprockets. The cams need to be in the same position as for a valve check (i.e. lobes not in contact with the followers).
