Is My Front Axle Missing Something?
5 posts Started 9 Sep 2015 Last recovered post 9 Sep 2015 Wayback Machine snapshot 12 Sep 2015
I was cleaning my bike this afternoon, and I noticed that the front axle is not "symmetrical".
There is a big bolt at the end on the right hand side, bot nothing on the left. Should I be worried?
Thanks for your help!
[image: 2015-09-09 19.40.40 - copie.jpg] [image: 2015-09-09 19.40.50 - copie.jpg]
You are fine.  The side that is round has a shoulder, and the axle only tightens from one side.
Ouf ! Thank you very much! I'm going for a ride during the weekend, not a good time to miss a part!
When you remove that big nut from the right, you can stick a screwdriver or similar through those little holes on the left side and pull the axle out easier. - and don't let your calipers hang by the hoses when you pull those off. Always reattach them to the fork with at least one of their bolts. Changing your brakes and tires on a VFR is one of the easiest maintenance jobs you can do.
[image: Ready for new shoes!]
Yeah thats spot on how it should be that mate (:
End of thread · 5 posts recovered Wayback Machine snapshot 12 Sep 2015
