All - I've scanned the 6gen posts for a similar topic and couldn't find a match, so I'm starting what I hope will be a short thread.
My 2003 has been running flawlessly since I bought it in 2012. About 3 weeks ago, when commuting, the engine quit when accelerating from a stoplight. No sputtering or rough running, just quit. When cycling through the start routine - key and kill switch cycled off then back on - I noticed the FI light came on but no noise from the fuel injectors, or the FI light didn't come on at all. After a few seconds and repeated cycling, I could hear the injectors do their thing, and she started up as if nothing happened.
That happened twice on that commute, then no issues until today. I put about 500 local miles with no issues since this first happened. Today, same symptoms as above, but a few of the times the FI light would flash instead of light/no noise or no light/no noise. Happens under load starting from a stoplight, but has also happened on the freeway at speed.
Not sure if I just need to run a fuel treatment (I buy mostly QuikTrip Premium/Non-Ethanol fuel, but top with regular unleaded if on the road), or if the problem is electrical or some other issue with the fuel injection system.
...or if I'm going down the wrong path. May be TMI, but when I bought the bike in 9/12, it had @ 8k miles (<1k/year). It now has 30k - point being, it sat a lot in its youth, but is getting lots of use now, so I don't necessarily think its a fuel tank issue. I also have it checked annually by local dealers for all tuneups.
My money would be an electrical fault, either a bad earth or a slightly dirty switch or connector. Fuel issues don't present like this so unless your fuel consumption has shot up I wouldn't go there.
Switchblade's suggestion sounds like a good start (particularly if cycling the kill switch on/off bought the bike back to life), after that I'd pull each connector apart and inspect for corrosion and use some contact cleaner.
Start with the battery for it's the weakest link in the whole system... To
determine the condition of an Maintenance Free battery give it a
refreshing charge... wait 30 minutes... measure terminal voltage...
12.8 or higher is a good battery...
12.0 to 12.8 is a insufficient charge... recharge...
12.0 or lower... battery unserviceable...
To Swicthblade's suggestion, I have seen contact cleaner sprayed around the perimeter of the kill switch button give a re-start to a dead system. Enough will run down around the edges and get down to the contacts.
Your bike's going on 13 years old - a bit of inspection and maintenance of the electrical system can go a long way.
I always start at the cheapest fixes first, so last night I drained the tank (@ 2 gallons), put in fresh non-ethanol fuel and some Sta-Bil. Bike idled fine as I put everything away and back together. Literally the second I put my helmet on she died.
I only have an analog multimeter, and with no drain the battery appears just under or at 12 volts, and just under 13 when she starts up, so I'm going that route - will roll her over near an outlet and charge it up. While I'm waiting I'll check and clean the kill switch connections.
Was hoping to make my next bike shop visit in the Spring, but will check it out now...
End of thread · 10 posts recoveredWayback Machine snapshot 17 Oct 2015
