Ok, so I took everyone's advice and got myself a great chain and sprocket set from sprocketcenter. Now I am in the middle of the project and have a few issues...
I realize NOW that I should have taken the front sprocket loose first so I could use the chain and brake for tension to get the front sprocket bolt loose. Since I didn't do it that way, anyone have any suggestions on how I can accomplish taking the front sprocket off with the chain already removed? (Yeah, in pretty proud of myself for getting as far as I did)
Also...
From what it looks like, the front sprocket looks alright (but I'm a brand new "mechanic" so what do I know?) but I was wondering if the sprocket should have that much play?
Also when I took the three bolts out of the thingy to get to the front sprocket (ok, I just looked it up - it's the clutch slave cylinder) the LONG bolts were badly rusted.
[image: ce17bf5c3fcae486c70688a9230cfdcd.jpg]
I was afraid to attempt to pry the cover off, so I left the short bolt in tact, and continued to gain access to the front sprocket.
[image: 37d02eb9e65c7a83d219c6aab9c59b11.jpg]
This leads me to a few questions...
1.)How do you suppose those long bolts got so badly rusted?
2.) Should I attempt to gain access to the clutch slave cylinder so I can see what it looks like in there (not that I would be able to understand what I'm looking at)?
3.) How should i remove the rubbery feeling grime from the sprocket surroundings and cover?
Sent from my Z987 using Tapatalk
