Hi guys,
I hereby seek for a suggestion from your side, as i am out of ideeas concerning the problem i have.
My Ride: Honda vfr vtec 2002
I had a frontal accident with motorcycle and i had the following damage:
-front frame
-front lights
-front fairing
I have replaced/repaired the pieces as follows:
-front frame -> replaced with a new one, but for a 2006 model (only difference was the size of the ECU bracket)
-front lights -> replaced with second hand lights bought from ebay. These lights are UK ones (it is written on them)
-front fairing -> stiched, repaired, repainted
Problem: the lights are aiming sky high.
I have done many tries as follows:
-visit a service to check the front frame and all the joints for correct alignment - OK
-visit another service to check the lights. they used a special device (don't know its name) with some kind of prisms to see if the front beams are aiming fine - OK
-hardened the rear shock absorber
-of course, adjusted the lights at the lowest position.
Even after these all things, the lights are still aiming too high; high beam does not even "touch" the road.
THe guys at the lights service told me that the beam is adjusted and is calibrated fine, but in reality, when i drive on the road, the truth is different.
The serviceman that i usually visit told me that the frame and the fairing are ok, aligned and just fine. In his opinion the problem comes from the front lights. I can't understand his statement, as the lights appear to be ok physichally speaking, with no defects. Being UK lights they are supposed to aim a bit high in the right side than in the left side, but not in the sky. Correct?
If anyone has an ideea, a suggestion or anything, it would be highly appreaciated, as i really don' know what else to do.
