Everyone is always messing with the clutch, trying to get it to behave like a normal clutch should. Out of the box when brand new, the VFR800 has a clutch that makes a little clutch basket rattle noise, at idle, in neutral, with the lever out. It is normal, that is just what they do.
Also when trying to launch at anything over 4000 RPMs, it varies from bike to bike, you can get a lot of clutch chatter that makes the clutch feel like an on off switch, instead of providing smooth modulation and feel.
This is also just a normal VFR800 trait, it is just what they do.
When Honda designed the clutch and hydraulic system, they set out with a few goals in mind. The VFR800 being a touring bike, they were after a light clutch lever, but with the VFR800 being as heavy as it is, with a decently torquey engine, the clutch needed to have plenty of torque holding capacity.
So what did Honda do? They gave the VFR800's clutch an enormous amount of frictional area to provide adequate torque capacity, while using light weight clutch springs. So in Honda's eyes, mission accomplished, they just successfully designed a clutch that can handle the severe duty of a heavy weight and some what torquey touring bike, while still providing a light comfortable, touring friendly lever.
Sounds like a win-win right? Well not really... With all of that frictional area and springs that are really light, you are left with clutch that has springs that are too weak to control the clutch pack. The springs prove to be adequate at lower RPMs, but at higher RPM launches, the clutch pack becomes unstable and you get a lot of clutch chatter.
So what does your average VFR owner do? They try all the different lever positions. They bleed out the lines a million times and put all new fluid in the system trying to get any possible trapped air out of the hydraulic system. Some even go as far as to polish the push rod and debur the basket and plates, I know I did, but to no avail. All this work, to fix what you think is an aging clutch that needs to be replaced lol.
I did it all and just as I was getting ready to throw in the towel and buy all new oem plates and a new basket, when one of the members on here (Toecutter) was having his own clutch problems, not due to the inherent VFR clutch chatter, but due to the fact that he had installed a super charger and the 200whp was burning up his clutch in the upper gears when under boost.
So he was trying everything he could to get more holding capacity out of the VFR's clutch, from experimenting with Barnett plates for VFR all the way to CBR's or some heavy big displacement cruisers and even adding an extra plate or two. Nothing seemed to do the trick and some seemed to worsen the chatter or cause other weird characteristics.
Eventually he thought about, instead of increasing the coefficient of friction or the frictional area, why not just increase the normal force (spring pressure)? He messed around with shimming the clutch springs and the off the shelf Barnett springs, which helped a little, but didn't quite give all the holding capacity needed for super charged application.
Then finally he found a set of custom Barnett springs that were made for an aftermarket big twin's clutch that just happened to fit in the standard VFR800 clutch housing, but had 99 lb/inches of seat pressure. These springs, when used with the factory oem VFR800 plates, are able to hold all the power of a supercharged VFR800 and they had the added side benefit of being able to stabilize the clutch pack for 9000 plus RPM launches. Two birds with one stone, Win Win.
I have been using the 99 pound barnett clutch springs:
(Barnett Springs 99lb MT-91-6, 501-99-06091, TR 49-0747)
for a few years now and they have been great. They definitely add a good amount of lever effort and are not for the faint of heart, but they totally eliminate all high RPM clutch chatter. Later on I upgraded to a Brembo radial master cylinder, a +2mm HRC/TSR slave cylinder and an SS clutch line to lighten up the clutch lever weight some what and add some more feel. I have to say, the feel, lever weight and ease of high RPM modulation is fantastic with this set up.
AND THE BEST PART IS, I AM AT 70,000 MILES ON THE FACTORY PLATES, AFTER LAUNCHING AT 9000 PLUS RPMS AT THE DRAG STRIP FOR YEARS. I really cannot stress this enough, There is no reason to mess with the factory clutch plates. Maybe after you hit 100,000 plus miles, the bike sits for years, you accidentally roasted the clutch/warped the plates from launching in sixth gear or some other weird instance, but I have been abusing the crap out of my factory Honda clutch plates for 70,000 miles and they are fine.
I mean seriously, I ride like a complete squid, do clutch ups and drag nights, 9000 plus RPM launches 24-7 and the factory plates are fine. Every time I see someone installing a Barnett clutch kit on their 20,000 mile VFR800, I cringe. People are wasting time and money on a fix that in reality is probably just going to make it worse.
Yeah some people report that after installing a Barnett clutch kit, it feels slightly improved. That improvement was not due to changing the plates out, that slight improvement in feel was from changing out the marginal and possibly tired oem springs, for slightly stiffer and new, Barnett springs.
Edited March 15, 2016 by CandyRedRC46
