Did my yearly oil change the other day and noticed two empty holes below the coolant tank on the left side. Lookin into them with a light they don´t seem to have any threads? Is it supposed to be like this or are they missing?
If the bolts remain (presuming head snapped off), replacement might be as simple as removing the clutch slave for the upper and w/p for the lower and using pliers / vice grips to back the bolts out. With only 2 bolts on the clutch slave, the remaining two are taking an off center load when the clutch is pulled in, so definitely worth replacing before something else gives.
End of thread · 4 posts recoveredWayback Machine snapshot 11 Sep 2017
