Well after reading all the positive result comments on upgrading the viffer's stock cartridge fork internals, I coughed up some dough to Jamie Daugherty for a complete fork kit and a re-built shock. I will just discuss the fork work here for now. sorry if it is a bit wordy, i will add some picks later.
After filling out the order forms, anticipating how great my new suspension is going to work, and waiting impatiently for the goodies to arrive...... which they finally did....I am now in the middle of the process.
Being a do-it-yerselfer, and stubborn, i figured that after watching some you-tube, reading lots of forum discussions, and studying the excellent and detailed instructions that Jamie sent with the parts.. How hard could it be?? One wise guy on the forum says: "just send your forks to Jamie, drink a beer on the couch while he does the magic, and enjoy....." that is not bad advice, but it now where near as much fun as getting out all your own tools, maybe buying a couple new ones, and digging in.
I had never even looked inside of a motorcycle fork until two nights ago, but now i have had some up close looks. I have gotten through the hard part, i think, i have the forks completely dis-assembled, and almost ready to install all the pretty new internals.... almost.
Tip #1: If you want to do this your self, it isnt too bad, just be patient... but if i were to start over, the first thing i would do is take the forks off and go straight to a mechanic or friend who has a high quality pneumatic tool kit to spin out the pesky bolts from the bottom of the fork slider that hold the bottom compression valve assembly. I mentioned i am stubborn. I saw lots of vids and read comments that noted removal of these with simple hand tools, other peeps commented that the cartridge might spin..... hmmmmm how hard could it be??
The left bolt came out easy, no problem. I smiled and thought this will be easy.. ha ha.. The bolt in the bottom of the right fork leg was very stuck in the cartridge, and it just spun and spun and spun... ugh.. I tried all the tricks i could find, and even went to the Honda shop where they put the high speed impact wrench to it.. No love, they didn't get it out either.. I am not certain but I suspect that if I had not first spun it with the hand wrench, using the impact tool first probably would have removed it.. who knows. its history now.
So........... I had to drill the bolt out. it was a tedious process but I got it done. I used a bit just a fuzz larger than the shank of the bolt, (which i could measure cuz i luckily already got the other one out) Since i had already gotten the cartridge spinning, the bolt head initially spun with the drill bit! Gah! So i drove in a couple short pieces of ss bicycle spokes between the bolt head and the housing to wedge it, That worked. I drilled through the cap screw head without enlarging the hole on the slider. When done i had the hollowed out bolt head and the copper washer on my drill bit, but the cartridge assemebly was now free! The rest of the un-do work is a cinch, (especially with Jaimies instructions)
So after sliding the bottom valve body out of the cartridge tube, the threaded stud of the bolt remains in it. It is stuck tight too!
The bad, or maybe not so bad...the afore mentioned almost part... Now i am going to replace the fork seals because i have metal drill shavings inside the fork tubes and i can see no way to be certain they are completely cleaned out without doing that..I had never had any seal leaks so i wasn't initially going to do that, so that will be one extra step, the fork has 36000 miles and is an '08 so i figure it is just good maintenance, anyway! That and a new cap screw and couple new copper washers, and i will be ready to reassemble.
More to come soon! I will try to get a few pics too, Cheers!
Edit 5.15.16 added shock replacement to the thread.
Edited May 15, 2016 by jimbobreworded title
