The RH grip on my 08 6th Gen has failed. I had Honda heated grips fitted when I bought the bike from a Honda dealer back in 2010. I'm trying to remove the rubber grip & heated element from the grip assembly (which attaches to the throttle cables) but they appear be glued together!
I've checked the parts fiche and the rubber grip & grip assembly are definitely listed as 2 separate items but in this guide to fitting the Honda heated grips, they appear to be a single (glued?) item.
I'm guessing that in order to replace the grip, I need a new grip assembly as I'm really struggling to separate the 2 so I can slide the replacement on.
Can anyone confirm this?
[image: IMAG0717[1].jpg]
