HONDA VFR800 VTEC ABS
4 posts Started 6 Dec 2016 Last recovered post 11 Dec 2016 Wayback Machine snapshot 18 Jul 2017
hi there all . i new to this sort of thing. so thats have a go . i have a 2007 honda vfr800 vtec abs. witch i think has a problom with the alarm/immobiliser. when i turn the alarm/immobiliser off then tun the key on you can hear the fuel pump fire up . some times the fuel pump does not fire up and it is getting whorse . if i keep fiddling with key and alarm fob it will cut in but not all the time . is there a easy fix for this . or do i have to take it back to honda many thanks shane from the uk
Do you have another key with a transponder chip on the same ring by any chance ?
Agree completely with RC36Rider. Any other key near by with a Transponder chip will confuse the HISS system. Also if you have your spare key give that a try, but don't have the two keys on the same ring.
Get shot of the alarm.
End of thread · 4 posts recovered Wayback Machine snapshot 18 Jul 2017
