I noticed a rattling this morning on the way into work (heard it due to forgetting my ear plugs today, not sure how long its been there!).
It seems to be when I release the throttle and decelerate, but it only seems to happen when I am in a gear above 2nd. If I shift down it seems to go away.
There are no issues with braking or loss of power when I then accelerate again etc.
Any ideas what could be causing this? Not sure how serious a problem this is/could be.
Most common cause are the CCT's Cam Chain Tensioners. One for the front, and one for the rear cylinders. Try to establish wether the noise is coming from front or rear cylinders then replace it. Generally you can hear it when engine fully warmed up and at idle. Search the forum, there's heaps of info regards this common issue.
If it is the CCT, many have ridden (including myself) with the noise for a while without an issue. If it is really bad and ignored for a long time there is a chance of the timing chain jumping a tooth on the cam sprockets which could potentially cause piston/valve damage.
Check your chain tension. When the chain on my former '02 was stretched beyond adjustable length it rattled on deceleration, sound seemed for all the world to be coming from the front of the bike.
PACIFICMAN Check your chain tension. When the chain on my former '02 was stretched beyond adjustable length it rattled on deceleration, sound seemed for all the world to be coming from the front of the bike.
