I am hoping someone might be able to help me. I posted a while back that I changed my rear cam chain tensioner plunger and since re-installment the motor will not start. It turns over, the starter sounds normal but I will not light off.
Electrical:
I have checked the battery. I jumped it from a portable jump start pack just to make sure it wasn't the problem. The battery is giving good volt meter readings (about 13.2 unloaded, 12.4 loaded).
I checked the fuses located in the front right fairing.
I searched to see if I might have disconnected something accidentally but couldn't find a anything (there isn't anything over there).
I put a timing light on the coil wire and was receiving a flash (even though my last attempt to re-verify didn't seem to give me a flash).
All other electrical items seem to be working normally (neutral indicator, side stand cut out, etc.).
Fuel:
I removed the air cleaner and put fuel in the throttle bodies. Nothing. When I attempt to start eventually the tailpipes smell of fuel.
When attempting to start, if I hold the throttle open about 1/2-3/4 the motor does seem to stumble a little but it still does not light off.
I am truly mystified as the bike was running fine prior to the work on the plunger being done. Removing the plunger and replacing it with a new one is all I did. The bike literally only sat for three days between my last use of it and being done with the work.
Any advice or suggestions would be greatly appreciated as I am at the end of my thought train and am about to take it in.
Thanks.
Matt
