I wonder if someone here can help, I did a spark plug, air filter and oil change and oil filter service over the weekend and now it is reluctant to start, runs rich (strong smell) and is a bit spluttery. This is a standard VFR, no power commander, standard exhaust etc.
On further investigation (I apologise in an advance for my lack of technical knowledge but will describe things as best I can) the throttle bodies is it? - the four round things that open with you crank the throttle - as you sit on the bike I would number them 1 - left hand front of bike, 2 - right hand front of bike, 3 - left hand back of bike (nearest seat), 4 - right hand back of bike. Numbers 2 and 3 had smoke in them when the bike was off & numbers 1 & 4 were clear when and I cranked the throttle, this was after I had run it for a couple of minutes.
I did remove the whole airbox and had to replace it due to a stuck screw.
There are no FI errors.
I realised I MUST have screwed something up but I don't know where to look!
