Stator Confusion
10 posts Started 11 Apr 2017 Last recovered post 3 May 2017 Wayback Machine snapshot 24 Jun 2017
Alright folks looks like it's my turn to suffer electrical gremlins. I've confirmed the stator is toast on my 2002 and I'm confused on what part number I need for a replacement. It looks like, based on my measurements, that I do have the new larger stator so will any 2003+ do?  [image: F80i-MeyYKR1zt0RyUyXWDGwIQ3V0hN4QE1ygBc3]
It looks like yes, but i'm pretty sure all oem stators will loook like that after some miles...
Check your oem ref at https://www.bike-parts-honda.com/
And from that point you can check wich ones do fit and wich ones do not.
Make sure the stator is compatible (size-wise) with the flywheel, aka rotor, too.
Thanks for the advice. New stator is definitely the same size as the old one. Got that Installed along with a Rick's regulator/rectifier today. Just waiting on a VFRness and then a new battery and she should be all good to go again!
Kedge, ‎4‎/‎18‎/‎2017 at 6:47 PM
Good for you doing all those together.  That's how I did it on my 2004.  Did you use the string trick to fish the new stator connector to the right side?
1 hour ago, 2thdr
I did, and it worked like a charm! I'm getting around 14.2 volts at the battery at idle now with the VFRness installed.
In my case, I only replaced the burnt out stator and the bike is back on the road. I've also relocated the rectifier to the back near the passenger foot peg to allow for fresh air cool the rectifier. I live in the tropics (Nigeria). The rectifier now cools down.
Sent from my SM-G935F using Tapatalk
Man! That is ugly. Good move.
Same Kentucky fried pattern as always, with 3 bobbins at 5, 6 & 7 o'clock still a creamy colour.
End of thread · 10 posts recovered Wayback Machine snapshot 24 Jun 2017
