Will Start but not Turn over
3 posts Started 24 Apr 2017 Last recovered post 3 Jun 2017 Wayback Machine snapshot 13 Jun 2017
Hey Guys,
I need your help. Ex VFR user. My current motorcycle doesn't seem to start. I have a 2004 Hornet 599 with 17k miles on it. When I try starting, the hornet starts but doesn't turn over (see video). Would definitely appreciate all the help.
Following is what I did to the bike;
- replaced my spark plug
- checked the fuel lines for kinks (fuel lines were brand new)
- battery showed 12.8V
There was gas still reaching the carbs after I drained it. Not sure what to do next. following is a video of the problem.
https://youtu.be/aUoMs3bs-EA
Thanks in advance for all the help
Napoleon
thats turning over with no start. have you checked to see if you have spark , air and fuel.
Did you do something to it before this arose? I wasn't getting fuel once on my 06 because I pulled the vacuum line from the petcock while lifting the tank. Your plug wires or boots may have come loose. Your coil could be bad or not getting power, maybe.
End of thread · 3 posts recovered Wayback Machine snapshot 13 Jun 2017
