What is this sound?
8 posts Started 13 Nov 2017 Last recovered post 14 Nov 2017 Wayback Machine snapshot 18 Nov 2017
Hello guys, I'm pretty much new with the VFRs, I just purchase this bike for a really low price, the previous owner got pregnant and they needed the money, they were doing an stetical modification but I know there is some maintenance that need to be done.
Now here comes the cherry of this cake...
What you guys think it could be the sound of it? I heard people saying that is the camshaft, the valve caps that need calibration and other things... But I would like to hear your opinions.
Thank you! :D
Btw, this is a VFR 750 1990 and I hope to be the one conducting all the maintenance and repairs on it
WhatsApp Video 2017-11-10 at 6.27.23 PM.mp4
WhatsApp Video 2017-11-10 at 6.27.19 PM.mp4
WhatsApp Video 2017-11-10 at 6.27.15 PM.mp4
Without being able to determine where it is coming from, I'm at a bit of a disadvantage.
Could be valve train related but it reminded me more of rod knock, especially the intermittent nature of both the pitch of the sound and the frequency it occurs.
You'll have to tear into the engine regardless, I can think of no external failures that make a noise like that  Could be something loose hitting the engine, but I wouldn't bet on it.
Cam chain tensioners? I can't tell what year of bike it is and whether or not it has gear driven cam or cam chain. Sounds like the clacking of a cam chain which I had on my 2005. Pretty easy fix and about 200 bucks. The sound would go away on mine off idle or under tension.
That sound is "Expensive!"... HTH
The fact that it seems intermittent and relatively light would make me think top end?  I'd pull the valve covers and check for something amiss.
superfunkomatic Cam chain tensioners? I can't tell what year of bike it is and whether or not it has gear driven cam or cam chain. Sounds like the clacking of a cam chain which I had on my 2005. Pretty easy fix and about 200 bucks. The sound would go away on mine off idle or under tension.
The bike is a vfr750 1990, the sound is coming more from the engine than from any other place, and as you can hear, it is LOUUUDD :'(
This is a gear driven cam, and I hope I don't have to replace a camshaft
Enviado desde mi Nexus 6 mediante Tapatalk
Your location says, "COL".  I'm uncertain whether that means the country of Columbia or the U.S. state of Colorado?
If your location is actually Colorado you can go to Harbor Freight and get a "Mechanic's Stethoscope" (really cheap, just a few dollars).  The mechanic's stethoscope is a great tool for tracking down the location/cause of an engine noise.  It allows you to be very precise when listening.  At normal idle engine speed you can easily determine whether or not the noise is coming from something in the valve train (the noise occurs at 1/2 crankshaft speed) or whether it's coming from something crankshaft related (the noise matches the engine idle speed).  That can give you a good start and some direction to go in to correct the problem.
GreginDenver Your location says, "COL".  I'm uncertain whether that means the country of Columbia or the U.S. state of Colorado?
Hahahaha it is a bit more far than that, I'm actually in Colombia, but still it is a good idea to purchase that tool, I still can order it and get it delivered here, I'll definitely check it out :D
End of thread · 8 posts recovered Wayback Machine snapshot 18 Nov 2017
