New member
8 posts Started 13 Feb 2019 Last recovered post 7 May 2019 Wayback Machine snapshot 15 Sep 2019
Hello, new member test posting, Just bought vf500, needs recommisioning , looking forward to learning lots on here
[image: 6EF1DEE4-9D89-48A6-BE67-057FE6EA10ED.jpeg]
Welcome to VFDISCUSSION!!!
[image: IMAG0877.thumb.jpg.8dd03021655eeae21b1d2228fd5e3a41.jpg]
Welcome Aboard!
Hello Dutchy and Duc2V4,  just got this bike , will be hoping to get it running over easter time , Going to clean carbs , check fuel lines, filter, tank, change oil and filter and keep my fingers crossed, will update then , thanks
Hello, tried to start the bike over easter, fuel pump was not working, so by passed it . Started ok , a bit tappety but not too bad, But when I select 1st gear and release the clutch the bike stalls !!! . It doesnt appear to have a sidestand switch !. Could the cutch be seized ! Any advice or suggestions welcome , cheers Eamonn
[image: 54FC66DC-036E-4EF2-B1F9-8D46D6E50EF0.jpeg]
Put the bike on the centerstand and see if you can put the bike in gear without it stalling.
If it continues to stall, then you've got a sidestand cutout switch, and it's faulty.
If it starts and runs, but you can't get the wheel to stop turning, even in gear with the clutch in
then it's possible the clutch plates are stuck together. Not uncommon in bikes that have been
sitting for a long time.
But also check to make sure the clutch is actually working when you pull
the clutch lever. The master cylinder could be shot, or the slave cylinder could be bad. Either way
you need to check for actual motion of the clutch pushrod.
Eamonn, 2/13/2019 at 11:36 AM
Welcome!
Welcome to the asylum. You've obviously great taste in mc's. Cool machine. Good luck with your recommisioning.
End of thread · 8 posts recovered Wayback Machine snapshot 15 Sep 2019
