Hey folks,
So I think I have a fueling problem with my 6th gen. Naturally the symptoms started just after I installed the new performance headers and was starting to enjoy riding with them. I believe this is coincidental though, based on the symptoms. Which are:
- rough idling
- very poor low rpm performance (sputtering, missing, no backfire though), IOW, hard to get rolling w/o feeding in a lot of throttle to bring up the rpms
- relativly smooth running once moving, but seat of the pants performance feels sluggish. And when the throttle is let off, I can feel the engine get rough
I realize the description of symptoms is not very clear, but maybe someone has run into something similar and has suggestions. The issue did not come up on the first few runs after I installed the headers, but started a bit later.
No codes are being thrown ... yet. I have a RB unit with the std map supplied when purchased. I also have the RB module that can be put in place to restore the OEM mapping. I put the RB OEM module in place this morning, and that did not help. I have given a little thought to fuel quality, however, I normally run non-ethanol premium (RB map recommends premium) from a known source, so I don't think that's it. The bike does not sit outside either.
I am looking at using the 'shotgun' approach to get back to normal 'quickly'. I'm thinking of replacing the following items:
- fuel pressure regulator
- fuel filter
- wax unit (not to address the problem, but b/c I'll be in there anyway)
All of these items are presently original, and have ~40000 miles on them. My gut is telling me that the injectors are not the problem, I could be wrong though. I guess maybe coils could be the culprit? My voltage monitor does not indicate a problem in that area, but ...
The fuel pump is not on the list yet as it seems to be working. If I were to pick up a fuel pump, I'm looking at these folks:
www.highflowfuel.com
They list an OEM compatible pump for the VFR800 for $69.98. Does anyone have any experience with this distributor?
Anyway, if someone out there has suggestions on where to look, things to try, etc., I would appreciate same.
Thx for reading,
ACE
