I know the OEM drive sprockets have a rubber cushion on one side. Sprocket Center says they don't carry them. Partzilla's website doesn't make it clear if their sprockets (23801-MAT-760) do either. Where is the best place to get the "cushioned" ones?
sourcing (cushioned) drive sprocket for 5th gen
https://sprocketcenter.com/ognibene-52604-7039-530-pitch-rubber-dampened-front-sprocket-ducati.html
You sure? I don't know the tooth count you're looking for but I believe it sprockets and vortex both have sound dampened sprockets as well
Thanks skant. But yeah. I asked them. I need a 530 17T. They said they don't carry them with rubber. (And that I don't need it.) Well, I like em that way. 😉
I have a 17 tooth cushioned countershaft sprocket.
Just out of curiosity, why do you want to get one. I have one that I tried and took it back off after a very
short time. I'm willing to get rid of it because I didn't like it.
JT has them... uncushioned front VFR sprocket is JTF339, cusioned is JTF339RB
I don't really see the point. It's not really a "cushion" in that it doesn't make the drive any smoother, it's just something to make the chain a little quieter. Still, if that's what you prefer, they're available.
Yeah. Its about being quieter. Just what I've always had I guess. Maybe I'm afraid of change? 🙂
your chain shouldn't really be making a whole lot of noise to begin with but i get wanting the sound dampened one. If you can't get it in 530, is there a reason (other than not wanting to buy a new chain) you can't go 525 or 520? they're the same pitch just different widths. i suppose you could put a 530 on a 525 sprocket, there will just be some play, maybe put a .033 shim on either side?
[image: chain dimensions 520-525-530.jpg]
13 hours ago, skymonI know the OEM drive sprockets have a rubber cushion on one side. Sprocket Center says they don't carry them. Partzilla's website doesn't make it clear if their sprockets (23801-MAT-760) do either. Where is the best place to get the "cushioned" ones?
OEM is a cushion front sprocket.....just checked the one I have in my extra parts drawer....it has the same part number you list in your note.
